overheating 200 merc
tomoad
i put my thermostats back in, notice my popet valve leaking water out the vent hole, so i order me a kit to rebuild this, on the thermostats , the gasket goes around the thermostat right, in the slots notched out??? there was no thermostats in mine and had nothing to go by, my merc manual does show a good description, i cranked it up on da hose and ran hot thats when i noticed the water comming from the releif,
peterpagnott
Re: overheating 200 merc
The leak on the poppet could be due to the diaphram being stuck to the inside meatal washer. this happened to me. I pulled the whole thing apart and cleaned it good. When I replaced the diaphram it worked like a charm. and yes, the gasket goes around the thermostat.
KCLOST
With the poppet stuck open at lower rpms, water is dumped into the exhaust preventing sufficient water flow around the block, thus you overheat it... <br /><br />It should only open at higher rpms...
tomoad
on the diaphram, there's a washer on the outside with a screw and it screws into the popit, along with spring etc before popit,, how tight do you tighten the screw, i took the whole thing out a tighten the screw pretty tight, washer, diaphram, then stuck it in the hole, is this not the way you do this
tomoad
got it back together, for you all that have a temp gauge, what was your temp, where was the needle pointing, it didn't have any leaks from the poppit, and didn't run the motor to long on the hose and it got between halfway and 3/4 ways on the gauge,
gss036
I don't much about your poppet valve but your thermostats shoulb be 143 degrees. <br />If no responds, do a search or go to engine repair, maybe you can find the answer there.
gss036
I don't much about your poppet valve, never had one out, but your thermostats should be 143 degrees. <br />If no response here, do a search or go to engine repair, maybe you can find the answer there.
