stern pole light base cover...
Jixxxer
The rubber cap the covers stern pole light base on my boat is broken off and therefore Im left with a hole that water can get into. Do I need to purchase a new one or will it be ok like that? I couldnt find just a cover for it only the whole assembly. Great forum!<br />Thanks!
CharlesW
Re: stern pole light base cover...
I would definitely try to find a way to cap it off and keep the water from messing up the contacts. It might even cause a short when you try to use the stern light.<br />Our local hardware store has an aisle of cardboard drawers with lots of oddball stuff in them including some rubber caps/plugs. You might get lucky and find one that would fit your light socket.
rwidman
Your local marine center may be able to order just the cover from the manufacturer. It would be a special order and with shipping might be close to the price of the entire assembly, but it couldn't hurt to check with them. <br /><br />I've done this before with different parts.<br /><br />or:<br /><br />You might find a rubber stopper that fits at a medical or chemical (where schools get lab supplies) supply vendor.
crazy charlie
The next time you open a bottle of wine ,make sure you finish the entire bottle so you can use the cork to plug the hole.Black magic marker will color it so it wont look too bad.Charlie
Silvertip
Most hardware stores have bins/drawers with very specialized items. ACE and TrueValue are two. They have rubber corks (stoppers) that you could run a screw into to secure a short length of bead chain to keep it from getting lost.
scrapper
Ensign
How about useing a rubber stern plug ? stick it in ,Crank it tight , No Leak ....Scrapper
crazy charlie
Jixxer,I just remembered that I replaced mine in the spring and I may have the old one somewhere.Post your address and if I come across it ,I will send the cover to you.Charlie
Jixxxer
Originally posted by crazy charlie:<br /> Jixxer,I just remembered that I replaced mine in the spring and I may have the old one somewhere.Post your address and if I come across it ,I will send the cover to you.Charlie
THANKS!<br /><br />SHANNON,<br />411 WALL ST. <br />LAFAYETTE, LA. 70506
