cold start
Smoke eater
I have a 1983 90 hp inline 6 Brand new battery. It takes forever to get it started I hear the click telling me the choke works. Gas is getting to the carbs I can see it dripping out when I prime it, But the prime bulb does go soft. When it does start it runs great but if I shut it down for more than 30 min it is just as hard to start again. Please help I am a true Newbie in every sence of the word.
LubeDude
Re: cold start
Sounds like you need a complete carb rebuild with needles and seats, Maybe floats also. Its probably flooding to start with because your floats are not shutting off like they should. Replace the bulb also.
dcm3372
Re: cold start
I'd second that opinion. You should never see fuel dripping out and the bulb should go hard. <br /><br />Sounds very much like a flooding carb as in the valve isn't shutting off when the float gets up to the top.
Smoke eater
Re: cold start
thank you for the advice it will help. How do I figure out what rebuild kit to get I know there are three kind of carbs for this motor.
LubeDude
Re: cold start
The first thing you need to do is get a good manual so you can identify your engine. It will also walk you though the rebuild.
Smoke eater
Re: cold start
Thank you for you help, I will let you know how it turns out
hazmat918
Re: cold start
I have a 1969 Mercury 90 having the same trouble...how difficult was it to rebuild the carb..I am pretty good with tools, but not the best, should I have this done and what would the cost be?
Smoke eater
Re: cold start
The first thing you have to do is get a good manual and read the section on rebuilding the carbs it was not hard just keep track of the small parts.<br /> Good luck Hazmzt
