LubeDude
- Oct 8, 2003
- 6,945
Like Ive posted before, I purchased this Bass boat last fall. 18' 150 Merc I only had a few weeks to play with it before the rains came and it developed an electrical problem which ended up being a stator. Well, $383.00 later, I got it back today. Took it to the lake on the way home, and that problem is solved. I figured out an interesting thing this afternoon. It had a flat spot off idle, but would run good if you stabbed it. Rebuilding the carbs, and doing everything I could imagine doing never fixed this problem. I experienced this again today. I noticed when I put the boat on the trailer, that when the motor was tilted up a little, it idled better and had good responce putting it on the trailer. Also I noticed today while cleaning it up that there is no trim pin on the motor, someone had taken it completly out. (The long pin that sets the motors trim angle when down). For some reason the boat doesnt like it when the motor is trimmed all the way down. I dont think the exhaust ports are under the water, but I didnt have time to look. Seems fine though when it is just trimmed up just a little. I know I need to get a pin, buy why is the engine doing this, you wouldnt think it would matter? I guess Im going through the learning about the motor period.
