well I've heard the ups and down about timing my motor76-1150 merc. some say take the prop off some say never rev engine with prop off. as far as using the seloc manual it explains more about other models other than what I havebut anyway I purchased a 1000 gal plastic water tank 1/4" thick at tractor supply. It has a 12" diameter opening which i'll cut a larger hole to acommadate my motor and the top will keep water in at full throttle while setting timing.when I get everthing in order I will post a few pics to see what you think.
