Regulator/Rectifer 97 200 Merc carb
TampaTom
This is a new engine for me. Installed a new tach today and didn't seem to be getting a good signal. Traced the grey signal wire back to the top rectifer/regulator (2x20amp system). Switched to the loose grey wire on the bottom r/r and tach worked. So I'm guessing there is a problem with the top r/r or the part of the stator feeding it. I realize the proper method it to measure ohms and amp output, etc. However, I had another idea. Can I switch the yellow wires feeding both r/r's then test the tach signal from each unit? If I get a signal from the top r/r (which I'm not getting now), then I know the problem is the stator. If the top one still gives no signal and the bottom one continues too, then I know the top r/r is bad. Is there anything wrong with trying this? Will it be an expensive experiment?
dilligafda
Re: Regulator/Rectifer 97 200 Merc carb
Originally posted by TampaTom:<br />Can I switch the yellow wires feeding both r/r's then test the tach signal from each unit? If I get a signal from the top r/r (which I'm not getting now), then I know the problem is the stator. If the top one still gives no signal and the bottom one continues too, then I know the top r/r is bad. Is there anything wrong with trying this? Will it be an expensive experiment?
Answers to your questions, in order<br /><br />Yes, you can switch the leads.<br /><br />Correct, the problem would be the stator if that is the case.<br /><br />Correct, if the problem stays with the rectifier, then it is most likely bad.<br /><br />No, I do that in the shop whenever possible. Speeds up diagnostic time.<br /><br />No, the only expense will be if the reg/rec is bad.<br /><br />That is a common method of diagnosis in multiple systems like that. When all else fails, swap the suspect component with a known good part. Good luck and keep us informed!
TampaTom
Thanks Dilligaf,<br /><br />The problem appears to be in the upper regulator/rectifer as the tach only worked off the lower r/r regardless of which stator leads were attached (long or short yellow).<br /><br />Getting 14.5 volts at 1,500 rpm. Can I run for a little while with only the lower r/r (basically a 20 amp output)or could I damage something (like stator suppling upper r/r)by not replacing imediatly. I've been pourng too much cash into the boat budget this month.
dilligafda
The possiblity exists that you could damage the stator, more importantly though, you could have a short in the rectifier that could lead to a thermal event(volunteer firefighters don't like the "f" word). I would replace the rectifier as soon as possible.<br /><br />The choice is yours. Good luck!
rodbolt
hello<br /> yep but thermal events on the water way back the creek at the old fishing hole make memories:) :) . and they are way more exciting :) <br /> I would fix it but that is just me. look for blacked or burned looking connectors as well.<br /> good luck and keep posting
