Sputters at top end!
Wolfman
1989 Mariner 150 2.5l v6 cranks a little hard sometimes(Im told this is common)Runs great at lower speeds. But with rpm @ 5500 speed is about 54mph. And engine sounds(about 5 mins apart) like its missing or fuel is lacking pressure to keep engine steady at rpm. Fuel filter is new, water seperator new, compression 130+ or- 3 all around. Help appreciated<br /><br />Thanks, Wolf<br />Savannah GA
mellowyellow
Re: Sputters at top end!
try squeezin' the primer bulb underway and see if<br />it picks back up. at idle, squeeze bulb and see if<br />any gas is leaking from front of carb too.<br />post results.
Wolfman
Thanks Mello, This is my first outboard, squeezed bulb no fuel from any of the 3 carbs, but its started right up. Pressure in bulb remained pretty much steady during idle and a slight rev(about 2000rpm)for a few seconds. Will try to run it tomorrow.<br /><br />Thanks, Wolf
D
DJ
Guest
Wolfman,<br /><br />Also look very closely at your fuel line connector. It should have an 'O' ring on it.
mellowyellow
gonna guess fuel starvation. many poss. causes.<br />start at source of fuel and work backwards.<br />eg. first try a fresh/clean portable gas tank and<br />primer bulb.<br />good luck,<br />M.Y.
WillyBWright
If the fuel pump has never been rebuilt...do it. The rubber components stretch, harden, and crack over time. I wouldn't expect more that 10 years out of a diaphragm fuel pump. Parts are cheap.
Wolfman
Hi All! Checked fuel lines and guess what, no clamps just zip ties. Put clamps on every line bought a high flow fuel filter(see thru glass type) and found 2 small fuel leaks. Fixed them. Will try to run it this afternoon. And the fuel pump seems to be working fine. I get plenty of gas. But if what I've done all ready dont fix the prob, the fuel pump will be my next item to get inspected and fixed. So far all of your help has allowed me to fix several small problems. Thanks for the help! If yer ever in Savannah, GA look me up, Ill buy ya a beer or 2.<br /><br />Thanks Again,<br /> Wolf (Rick)
mellowyellow
areas that leak fuel also allow air into the sytem<br />especially when she's sucking hard at WOT.<br />finger's crossed ;) <br />M.Y.
Wolfman
Thank You all very much!! Motor ran fine with no sputters. 53 mph @ 5800 rpm. Everyone was very helpful. I have other quirks I'll post and I'll tell all my fishing friends about your great and informative site.<br /><br />Thanks, Rick :) :) :)
