Merc90HPnewbie
Thread starter- Joined
- Jul 27, 2003
- 178
Recap: 90 HP inline 6 tan band 1985. No spark on #5 cyl.<br /><br />I swapped the plug wire (with the same spark plug stuck in it) over to the #4 coil and it sparked. Then I put it back on the #5 coil and ran the #4 trigger wire to the #5 coil and it sparked. So I think I proved to myself that the #5 coil and plug wire are good. I went through the Mercury service manual to test the stator and trigger assembly. Everything tested right smack dab in the middle of the acceptable range. I tested the coil even though it obviously works, and it was in spec. I am unsure how the inputs and outputs of the switchboxes correlate, but am I right in assuming that I've isolated the problem to the switchbox?!?<br />Is there some way to move stuff around on the switchbox so I can make sure the switchbox is bad before I replace it? (I hear they're expensive).<br /><br />The book goes on about how you need some special tester for the switchbox (hmm sounds suspicious- need a special mercury-only test tool or else you can't replace the mysterious black box that you can only get from....Mercury?)<br />Anyway thanks for reading this.
