Re: Is 195 degree's or so too hot? 2.5 liter
Back to BillP's comment about salt crystalizing at temps over 140. Bill that sounds odd to me as the solubility of NaCl, MgCl, Na2SO4, and MgSO4 and most salts except carbonates increase with temp. Most of the salting up of cooling passages occurrs during cool down when residual salt water evaporates in the channels if it isn't flushed out and ultimately causes corrosion of the Aluminum into Aluminum oxides and Aluminum carbonates which are the real culprits as they are hard and relatively insoluble even in hot water. The salt deposits from the previous run will usually dissolve immediately during the next run.
