FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Check the compression and spark and report back to us please.<br /><br />Also..squeeze up the primer bulb and see if fuel leaks out the carbs.<br /><br />TMD
Did all that, still runs like ****, But today while out in the water, sprayed carb cleaner in bottom carb., ran good. until I ran out of cleaner. So what is it?
it may be misfiring because of clogged carby's .. Spraying cleaner in will do fawk all.. You gotta tear em into pieces and dip them minus the rubber bits in the carb cleaner solution overnight. They will come out brand new<br /><br />Then put it back together and tune the carbs... Before you do all that.. Replace the spark plugs, time the engine. It could be one of your powerpacks or coils are going bung too<br /><br />If you don't have a manualget one .. best $35 you can spend
