85 150 merc xr2 shift shaft seals?
CU2NITE
I just noticed I was leaking a bit of lower unit fluid out of the small hole on top of the lower unit. I pulled the unit and noticed the leak was coming from around the shift shaft. I see in my manual that it has a gasket and seals but it doesn't tell me how to replace them. Can anyone help me with this one? Do I need a special tool to pull the bushing off the shaft. A little stumped, any help would be apreciated.<br />Thank you<br />CU
The Marine Doctor
Re: 85 150 merc xr2 shift shaft seals?
Yes...there is a special tool to remove the carrier.<br /><br />Part# 23-77631a 2<br /><br />You can either replace the seals or the carrier complete with new seals.<br /><br />We currently stock.<br /><br />marine.ron@shaw.ca<br /><br />TMD
CU2NITE
I'm not sure if I can ask this question, but where can I purchase marine tools? I'm also looking for a spanner to remove the top of the trim cylinder, so I can replace the seals in there also.<br />Thank you<br />CU
The Marine Doctor
I have found the tools you need and can supply. EMail us <br /><br />marine.ron@shaw.ca<br /><br />TMD
CU2NITE
Thanks Doc I will contact you!<br />CU
