Merc90HPnewbie
- Jul 27, 2003
- 178
Ok, put new pump upper housing and impeller on lower unit. Driveshaft turned fine (when I was twisting the impeller into the upper housing-everything I read says to go clockwise). Went to install lower unit back onto leg, could not turn driveshaft in order to mate with upper half of motor.<br /><br />I figured maybe it went into another gear (controls on boat were still set to forward as it was when I removed lower unit) but I dont know how to tell. I moved the shift shaft around to different positions and sriveshaft still wouldnt turn more than 15 degrees or so. I assume I jammed something up and have to take the pump housing off and see if the driveshaft is bound up (maybe the 'key' slipped off the flat). BUT:<br /><br />How do I tell what gear the lower unit is in? <br /><br />How do I move the shift shaft - I'm assuming I just grab the splines with pliers (I put cardboard on the jaws to prevent damage)<br /><br />Thanks!!
