Re: Retrieving Lost Motor
I think it depends on the mud on the bottom. If the water is mucky, then the bottom usually is. It may have sunk in really well and might be difficult to see on a fish finder. With some luck though, it might be visible.<br /><br />What about dragging a really strong magnet along that area? I'm not sure how much of the outboard would be magnetic, but that might work.<br /><br />I don't know about underwater metal detectors, but that would probably work, though the setup would likely be too expensive to be practical. Does anyone know about this...? Can you get a $100 Wolly World metal detector, waterproof the detector portion by sealing it in plastic, and running a wire to the boat where you have the "viewfinder" or whatever that is called. Then just use your fishfinder to help navigate... Sounds crazy but it might work.
