FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: BLEEDING the Power Trim hydrolic fluid on a Mercury Outboard engine. HELP!!!
Shouldn't need to as it is self bleeding, but if you had it all apart, just crack the lines at the cylinders and run the TnT until fluid comes. Re-tighten the lines and motor the TnT up and down a few times. Be sure to keep topping up the reservoir while doing this. Be sure to leave the vent screw open...
i have just bought a 83 ranger with a mercury 150 blackmax took it out today and the trim will not trim up with the boat moving. you can stop and raise it up.it does seem slow to raise but not sure. this unit has the one cylinder under the moter and the pump and solinoids are in the back compartment. i see a wing like nut on the side of it and a plug with a flat slot in it above the wing nut. would air in the system do this. if not what might. i did have to jump the trim limits out because they were not working. and up would not run. jumped them and now it will raise.
but not when boat is moving.
