Troy_from _Oz
Thread starter- Joined
- Sep 29, 2002
- 126
Hi all, I recently replaced the impeller on my 71 merc 650 (4cyl) (see other post). On checking the engine running on muffs, I noticed water seeping out of the top cylinder between the spark plug threads
. on pulling the spark plug out, the outer section (thread area) looked corroded so I guess this may have been going on for a while. (Ive only owned the boat for about 6 months and replaced plugs then) I guess this means its time to pull the powerhead off? <br /><br />I did a compression test on the top two cylinders and each measured 125psi.<br /><br />Does anyone have any suggestions or thoughts as to where the problem is likely to be?<br /><br />cheers<br />Troy
