What to Clean Carbs with ????
85Mariner
I have a 84 Mariner serial #06455554 and i nead to know what to clean the Carbs with
Trent
Re: What to Clean Carbs with ????
Berryman's B12. You can get it at Wal Mart...great stuff!
FreeBeeTony
Is ok to use Gumout that you use on car carbs?
petryshyn
Don't use any cleaners on plastic, fibre, cork, rubber or neoprene parts. All carb cleaning areosol liquids will work on the metal components. Most are just a lacquer thinner......
Yepblaze
It will do next to nothing in the way of running improvements.
FlyBoyMark
Ensign
Gumout comes in two types; Alcohol or chlorinated flurocarbon with other solvents added. The second is the most potent...and dangerous and really cleans the gunk out by simply jus' spraying the part. The second also burns your eyes and skin like crazy too. Another alternative is to simply take the carb apart and soak in lacquer thinner and clean with a stiff nylon brush. :p
seahorse5
The May issue of Bass and Walleye Boats magazine has a good story on how to clean carbs. They say that carbon cleaners (Engine Tuner, etc.) work well on hardened carb deposits.
nnosker
like the above. carb cleaner and elbow grease.<br /><br />Also, I believe Sea Foam works wonders for all. Love this stuff. Wouldnt be without it.
Bob_VT
Call me old fashion but I completely take everything apart and let only the METAL soak in commercial carb cleaner. I bought it in a gallon can from NAPA and it works great. It will DESTROY plastic.<br /><br />I use a large coffee can (the old 3lb size) and soak the parts overnight.<br /><br />Bob
clanton
I use a GUNK product in gallon can, about 20.00. I<br />soak for no more then 1.5 hours for metal carbs, and about 30 minutes for plastic carb. Have had no problen with plastic carb parts melting. Ok on the OMC float for 15 minutes. USE THIS INFORMATION AT YOUR OWN RISK.
