flywheel puller
Neikensnest
where can I find a flywheel puller for 88 merc 135hp outboard?<br />Thanks!
RobinR
Re: flywheel puller
Neikensnest,<br />Your local Merc part dealer can order it for you. The thread and bolt size is common for all Mercs. Cost is about $60.
Steve135
Re: flywheel puller
Neikensnest- I have used a universal one from sears that cost about 22.00 and it has worked well for me. The bolts that come with it are cheap but you can replace them with better ones.<br />steve
ob
Re: flywheel puller
Neikensnest, you could even go one cheaper and gain use of one through your local autozone for nothing . At least the ones where I live will loan these tools at no charge as long as you give them your drivers license no.
Neikensnest
Re: flywheel puller
Thanks for all the info! I'll be tackling the stator, fire switch area soon.<br />Thanks again :)
