bruce conway
Thread starter- Joined
- Jul 16, 2002
- 4
not sure if my '87 90HP 3 cyl Mercury is charging. <br /><br />Voltage measured at rectifier is only 12.8 volts at 2500RPM. 12.5 at idle 800RPM.<br /><br />Because the rectifier output goes directly to the battery the battery acts like a regulator<br />(electrical sponge) and may be keeping the voltage low.<br />This engine has no regulator that I can see. I have a volt gauge on the console but <br />it is not very accurate. the gauge also reads the voltage at the end of a long engine harness<br />with relatively small gauge wires. My fish finder (Lowrance) reads the voltage as 12.4 to 12.8 <br />and drops to 11.8 with the lights on and 3500RPM. Again this is at the console.<br />bottom line is I have 3-4 hours use on this (new but used) engine and the battery seems fine.<br />trim works, cranks fine, just worried being stuck far from home.
