Fuel starvation prblms
seafever3
I have twin Mercruiser 60hp ELP Bigfoot engines on my houseboat.<br />When running upriver at aprox 3200-3400 rpm one engine<br />loses rpm down to about 2200 for about 1 min and then back<br />up to 3200 rpm for about a min then back down and so forth.<br />I have changed the fuel bulb several times and that does not seem<br />to help matters. This seems to happen only when the engine is<br />under a load. Going with the river current does not seem to<br />affect the engine. The other engine has no problems.<br />Thanks,<br />Dennis
petryshyn
Re: Fuel starvation prblms
Before spending time and money.....swap fuel lines and spark plugs to see if the problem follows.....
FlyBoyMark
Ensign
Compare peehole flow of other engine.......check fuel filter on engine too..seperate tanks?<br /> Are they open vented? :D
Dhadley
You might take a look at the anti siphon valve on that side also.<br /><br />Good luck!
