hello to all!! I've been reading a lot of info on the boards about cooling problems. Most of them seem to lead to changing the impeller. Now, our question....1986 mercruiser I/O motor, GM engine S/N A539386, 262 CID, 185 hp, V6, alpha one...When run in the water, no water seems to run through the engine, no noticeable water out the tell-tale, gets very hot very fast. Should we change the impeller first then go for the pump, or just change it all. Was not run at all last year, very little the year before. Where exactly is the tell-tale located on this particular motor? Not sure cuz we can't see any water!! Any suggestions would be greatly appreciated!! I just want to get out there and fish!!
Thanks and have a great day!!
