Mecury 850 Hard Starting
BassBomber
I have a 1974 Mercury model 850 that I bought last year. It starts great the first try of the day. However, after fishing approx. 1-2 hrs (with motor off & tilted up) the Merc is almost impossible to start. There seems to be alot of gas in the carbs when trying to restart. It will not even start after waiting 3-4 hrs. I tore down the carbs, cleaned them, put in new floats, and re-tuned them, last summer. The problem seems to be worse when the weather is hot. Thank you in advance for any advice.
petryshyn
Re: Mecury 850 Hard Starting
>have you checked for spark when it is hard starting?<br /><br />>are you using the fast idle warm up function?
ODDD1
I think schematic is heading in the right direction...classic trigger failure on these units is a no start after a heat soak....next mornin they work fine again....verify by checking spark when engine doesnt start...a pain, I know....but buyin an installin the trigger will hurt worse......
BassBomber
Several people have pointed out the trigger. can this be tested by an outboard technician, or does it have to be tested while on the motor/distributor? If it turns out to be the trigger, any leads on a good rebuilt one or a new one? Thanks again.
