Mercury 9.9 4stroke Hard starting,poor running
Pats20K
I have 2001 Mercury 4 Stroke which is terrible to start. Long, long warm up, factory and dealer response has been really poor. Is it me????? Appreciate any opinions
jegervais
Re: Mercury 9.9 4stroke Hard starting,poor running
Its been awhile since I've worked on a Merc 4-stroke, but here's what my past experiences have shown me - The fuel passages in these carbs are very small & it doesn't take much to block or partially plug them. Use of a fuel stabilizer (year round) is an excellent idea.<br /><br />I had a few (3 or 4) act this way right out of the box. I pulled the carb off and carefully took it apart (inside the shop on a bench, on a clean towel where I wouldn't loose any small parts). Althought they appeared spotless, I washed all the aluminum alloy parts with spray carb cleaner and dried with compressed air, paying close attention to all small drilled and machined passages. I re-assembled the carb, making sure float settings were correct. I removed the plug which hides the adjustable idle needle screw and set it to the initial dimension. Re-installed carb on engine and started and ran engine in a test tank (tank MUST be deep enough to simulate depth of water in/on mid-section when boat is in water). I adjusted the idle needle richer until I attained a nice smooth idle and acceleration. Coincidentally, starting was much easier.<br /><br />-John
WOOLY BUGGER
I HAVE AN OLDER 9.8 MERC 2 CYCLE, WHILE IT RUNS OK IT IS HARD TO START FROM TIME TO TIME, EVEN AFTER RUNNING IT FOR 30 MINUTES AND SHUTTING DOWN, IT TAKES 10 PULLS TO RESTART, I HAVENT TRIED ANY CARB CLEANER BUT THAT IS THE NEXT STEP.
My 2000 mercury 9.9 4 stroke starts on the first pull but takes 4-6 minutes to warm up before you can kick in to gear so it does not stall. So if any one has a solution please reply.
Darren
walleye seeker
Darren
This has the manual choke correct if yes they are very fussy when cold due to the small jets in the carb. Just have to learn that sweet spot with the choke lever till its warm
I have one more question do you know where the manual choke is located. I can posted some pix's if you would want.
how long is the warm up time on a 2000 mercury 9.9 4 stroke
