1984 90 HP Mercury tilt / trim release
Littlet
Is there a way to manually lift a 90 hp Mercury ob when the trim / tilt won't lift? The trim motor runs but won't lift the motor up...so I cannot even get it up to tow it to a shop.
petryshyn
Re: 1984 90 HP Mercury tilt / trim release
Hi<br />can't say for sure on yours, but my old merc has a knob on the bottom of the tilt motor pump assmy. that will release it from the hydraulics.
Bobby Powell
ditto to Schematic-<br /><br />I have a 84 90hp merc which has a knob on the bottom of the motor...turning it one way or another will release it...if all else fails, swap relays and use the "down circuit" to raise the motor and get it to the shop.<br /><br />Bobby
petryshyn
Littlet<br />maybe you'll get lucky and find that knob 'not tightened'. That would account for the unit not lifting. Or maybe its just low on fluid......<br /><br />good luck
mbb
To raise motor I think you open the knob. But to lower back down, you have to loosen bleed screw on top of t/t cyls on motor and bleed the oil out.
