1952 5 hp carb settings
josh555
Hi I have a 1952 5 hp johnson.<br />I am trying to find out what the jets should be set at.<br />#1 is the one that is on top of the motor (lean rich also the primer.<br />#2 is the one off to the side of the carb, where the primer pumps the gas into the motor :confused: .<br />thanx for any help.
rickdb1boat
Re: 1952 5 hp carb settings
Hey Josh<br /><br />Here's what I found for a 5.5 HP and should work fine with yours.<br /><br /> Adjusting the High and Slow Speed Needle Valves <br /><br />Adjusting the carburetor in a tank is not the same as adjusting for open water. You can do initial settings in a tank and then fine tune the settings once you are out on a body of water.<br /><br />Screw in the bottom (high speed) needle until seated and then back out 1 turn.<br /><br />Screw in the top (slow speed) needle untill seated and then back out 1.5 turns.<br /><br />(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting. <br /><br />(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
josh555
This is not the same carb. I think the high speed jet is seperate from the carb, there is a line that comes from the carb to a hole where you can see right in to the piston (I think) And then there is a jet that you can adjust at that spot.
Paul Moir
The initial settings for that side draft carb is the high speed control turned out 3/4 of a turn or 1 turn out from gently seated and the low speed turned out 3/4 of a turn. Start the engine (in the water) and go to full throttle, and let it warm up. Turn the high speed control until you get the highest RPMs. Then drop the throttle to the half-way point and turn (very slowly) the low speed control until you get the best idle. Then check the high speed again.<br /><br />If you're unsure of where these controls are, email me at paul.moir@gmail.com and I'll send you a diagram.
