roscottjr
Thread starter- Joined
- Jun 10, 2006
- 330
Engine starts but dies. I have rebuilt the carbs but the issue didnt change at all. When it starts everything sounds great but will only run for about 45 seconds or so. Every once in a while it will run just a slight bit longer. Cannot figure out the problem. I have checked the spark and compression but everything seems fine. I know the stator doesnt charge the battery but I dont think that would be the cause of it dieing like it does. Model number 60173 C, serial number J10997. Any help would be greatly appreciated.<br /><br />Also, the timing is set perfect but if anyone has one or knows where I can get one then I could use another timing linkage for this engine.<br /><br />Lastly, this is hydroelectric shift but the buttons were gone when I got the engine. It has been modified with toggle switches. I have acquired another control unit with the buttons but they dont work. Any ideas where I can get parts to rebuild the buttons?<br /><br />Thanks<br />Robert
