engine won't start
battery
got a 1987 60hp vro outboard. worked last year when stored.this year it will not start. there's no spark on any plug.the plugs tested ok on continunity. is there a way to check coils with a volt meter. or any suggestions as to what may be wrong?
Walker
Re: engine won't start
Are you sure your saftey lanyard is hooked up??
battery
yes it's hooked up, however is the button supposed to be in or out?
battery
the lanyard was broken, and I did not see it so i took it off and pushed the button in and the engine started up the first time. thanks for the advice.
Angiecobia
I'm having the same problem. My evinrude won't start I just posted, But I came across this post. Whats the lanyard? Perhaps thats my problem..<br /><br />Thx
