Glassmaster77
Thread starter- Joined
- Apr 15, 2006
- 13
Purchased the boat 2 months ago. Been out 3 times. First time out motor was very hard to start after sitting up for several months. Ran OK, just had low idle. Would stall when going into gear. Pushed a 16' fiberglass Glassmaster 40 MPH with 4 adults. Plenty of power. <br /><br />Second time out, the starboard coil came unplugged after putting the engine cover back on and we limped back to the dock and trailered it home and discovered the problem. On the muffs it ran fine after plugging back up. Bumped up the idle and you can start it with a rope when its warm.<br /><br />Third time out, took it out about 10 miles up river and anchored for a few hours. On the return back at WOT running smooth it stumbled & then died. Started back up and ran rough. Limped back to dock. Trailered home and checked it out. Everything plugged and well grounded.<br /><br />It will start right up and run with the warm up lever slightly up. Drop it to idle and it coughs and misses and runs very rough.<br /><br />Changed spark plugs. Ran it about 10 minutes on the muffs. Port side top plug is black and wet. Other 3 are clean. Port power pack passes diode test. Spark present when I pull the plug wire and there is an RPM drop when the wire is removed completely from the plug. <br /><br />Can a power pack be bad on one coil?<br /><br />Does this sound like a weak or bad coil?<br /><br />The port power pack is blue and a different part # than the Starboard one which is black and part # 582125<br /><br />Compression is 120# on all four cylinders.<br /><br />Motor is strong and comes up quick. Thanks in advance for any help.
