Manipulator
Thread starter- Joined
- Apr 11, 2005
- 743
I am thinking about purchasing a lift after I just spent $334 dollars for the marina to look at my boat for loss of power. He checked her out from the engine to the prop (so he says) and has found no mechanical reason for a loss of power. Turns out I had a half-inch of fresh water gunk attached to the haul. I should of known better but did not understand how that much crappiola could rob me of so much power. Anyway, he pulled it out, power washed it and supposedly we are back to normal (havent gone to the lake to actually took it for a run yet). He gave me three choices: 1.) Paint the bottom. 2.) Take it out and put it on the trailer every weekend. 3.) Get a lift.<br /><br />Out of those three, which is the most economical? Im thinking lift but then Im stuck with renting the boat slip year round. I thought about the paint which would probably cost around $1000-$1500 and then it has to be done every so often for about the same price. Then I thought well Ill take her out and put her on the trailer but that can be a real pain and I have to worry that there would be a slip available every weekend which I doubt will happen. So what do you think? If I purchase a lift what is a good ole workhorse? I hear that Hydrohoist are great but they have come out with newer plastic tanks such as Econolift. Should I go new or used?
