Re: 1965 Johnson 9.5 compression
If the cylinder pressures are only 60lb. you may as well rebuild it. <br />Even if you can get it to start it is at the extreme limit and is only going to get worse with use. Somewhere between 50-60 pounds these motors get to the point where there isn't enough pressure to get them to light off. Also, low cylinder pressures indicate that a lot of pressure is getting past the piston rings. When you run a two-stroke motor with bad rings combustion gases get into the incoming charge and lean the mixture severely. It can make the motor heat up badly and even burn pistons. And, of course, your HP will be way down. <br />If you decide to use this motor, as is, be sure to take your oars.
