Racerpilot
Thread starter- Joined
- Apr 1, 2006
- 1
1977 85 HP Evinrude V-4. Trying to drop lower drive. Cannot disconnect the shift rod. I see where the rod connects to a bellcrank, just can't see a pin or screw to remove it. As per similar problem I read about in this forum I removed the lower carb, but can only see a flush ground pin connecting the bell crank to the rod. Also was wondering if the shift rod is keeping the drive from dropping down after removing the bolts connecting the lower drive to the exhaust housing. It drops about 1/4". Am I just being to timid about dropping the unit down or is the shif rod holding me up. The Clayton Manual I am using leaves much to be desired on this particular procedure. Thanks
