guardian452
- Mar 15, 2006
- 15
First off, what a great forum! Keep up the good work! <br /><br />Not too long ago, I got the urge to own a boat. Something big enough to have some fun with, but something old enough that I could afford. "Old enough" really means that I was willing to buy something cheap, even though it might need a little fixing. I don't mind fixing stuff because that's one of the best ways to learn.<br /><br />I got what I bargined for from a friends brother. An older 16ft fiberglass cutter with a deep vee hull and a 1969 85hp Johnson Hydroelectic shift motor. The boat needs a new floor and paint job, and the motor has a few issues that made themselve apparent after a few brief sea trials. For this topic, I'll only talk about one of the problems. <br /><br />But first I just gota say....What possesed anyone to design and manufacture such a shifting system! Yikes.<br /><br />Anyway, when I got the boat home, the very first thing I did was replace the water pump impeller and the oil in the lower unit. Even though the previous owner said that the motor had been properly prepared before being put into storage, I noticed that the gear oil was slightly cloudy when I drained it for the first time. I figured I'd keep an eye on that.<br /><br />I ended up changing the lower unit oil several times during those first test runs because the oil was obviously being contaminated with water.<br /><br />I know that the leakage could be from the Filler and Vent screws, but I have reasons to doubt that. <br /><br />Now that the weather is getting warmer, I can start working on the boat again, so I've started my first engine project this year by pulling the lower unit to change the seals. After removing the upper drive shaft bearing block, those seals do look a little rough, so I think I'm moving in the right direction.<br /><br />I just ordered a lower unit seal kit(Sierra), from my local dealer, but something the parts guy said to me made me think twice. I ordered the seal kit for the 1969 85hp "small prop shaft" beacause this matches the year of my motor. <br /><br />But... the previous owner told me that the entire lower unit had been replaced after an accident. I can see a set screw in the side of the lower unit near the water intake holes, that is not shown in my 1969 drawing, but is shown in my service manual (not factory) as part of a 1972 lower unit. <br /><br />The seal kit for a 1972 85hp OMC is descibed as being for a "Large Prop Shaft".<br /><br />Does this mean diameter, or something else? Could someone eloborate on this?<br /><br />I have measured the propshaft diameter on this lower unit as being exactly 1 inch. I took this measurment just outside of the prop shaft oil seal.<br /><br />Any comments would be greatly appreciated. <br /><br />Sorry for the ramble.<br />Thanks in advance.<br /><br />Sean
