Looking for a simple part.
flech01
I am looking for the nylon spacer(connecting rods piviot on these) on the carburetor for a 1976 115 hp Johnson. I can't find it on IBoats. If anybody has a part # it will help.<br /><br />Thanks for the help.<br />
OBJ
Re: Looking for a simple part.
PN 313329. Around $3 from your local John/Rude dealer.
lark2004
long shot here, but try a hobby shop. They have all sorts of little things that con be used on motors. Try and find one that sells large scale cars or planes.
lark2004
or do as OBJ says.....<br /> :D
OBJ
I would get the keeper called for. Anything else jury rigged in might cause you some trouble with the linkage sync in the future.
flech01
The ones I have on the carbs now are ok but I am rebuliding them so I thought if I could order off the web I would but I don't think Iboats sells them.
flech01
Thans for the fast response guys I will look for them.
flech01
Hey can I find that part online?
KYHunter2
Id say you can, if i-boats doesn't have them. Just do a search for oem johnson/evinrude parts. Or something like that . Google does well. Probably cheaper at a local dealer, by the time you add shipping. Unless you have other parts to add.<br /> KYHunter
ezeke
Don't see them on iboats, but ishopmarine.com will have them. Put in the number that OBJ gave you at the very top center of their home page. Best deal is bag of 5, I think.
flech01
Any idea what they are called
ezeke
313329 Almost always "retainer", very frequently "retainer link", often "retainer link carb(uretor)" and several others depending on use.<br /><br />It is all on the BRP parts diagram site at Evinrude.com.: Bombardier Parts Diagram <br /><br />You just enter the part number only at the search, "advanced" area. All of the part names with that number come up and you can then select from that to see where the part was used. <br /><br />Also in the advanced area you could, say, enter "Spark Plug" for the part and 1975 for the model, and see a list of plugs used in that year.<br /><br />Hope this helps.
flech01
Thanks I found them
