150 Ficht new ECU dead in 5 minutes
victoryrd
My son purchased a 1999 Crestliner with only 250 hours on it from the WI DNR. Well maintained but with a few minor problems. The DNR Warden told us it might need a new ECU and he was correct. We took it to an experienced Evinrude dealer that sent the ECU to the factory in exchange for a new one. On the first trip out, the motor ran fine for about 5 minutes total. The engine killed, then it started, but died when put into gear, then it never started again. We pulled a few plugs and found a smoked piston. Do you have any advice for us? Do you think we have any recource with the dealer? Or should we start to look for another power unit? The Ficht is a 1999 150 sn#E150FPLEEA, any help would be very much appreciated. Thank you,Paul
WillyBWright
Re: 150 Ficht new ECU dead in 5 minutes
Welcome to iboats. :) <br /><br />Those motors had considerable problems. There was an update kit that helped some, but nothing cured them. If you used any stale gas, that's likely what trashed the piston. But it could've been other things too. I'd look for an entirely different motor.
victoryrd
Thanks for the quick response. The gas was fresh, but I have the same concerns about the Ficht engines.
bucky4
I feel for ya man. We both got taken on the early Fichts. (along with many, many others!) <br /><br />Mine blew for the second time late last year. Still looking for a replacement, but No more Fichts for me!!!
Dhadley
Which factory? Did you indeed send it to the Bombardier factory for exchange or to DFI Technologies?
victoryrd
I'm not sure, the dealer had it for at least 45 days and said that the factory would not issue a new ECU unless they had the old one.
Dhadley
That is correct but where did he send it?
victoryrd
I don't know where he sent it
Dhadley
That's what we need to find out. One place has a warranty, one doesn't.
victoryrd
I'll check with the dealer,..thanks
