Evinrude 70 hp
lloydy
I have an Evinrude 70 hp and not sure what year mod it is because the compilance plate is damaged <br />this is all the information I have, <br />Ser no G03173148 Mod No E70tc or E70tL not sure wich one it is.<br /><br />Thanks Paul
OBJ
Re: Evinrude 70 hp
There's a large welch plug on the block. The model number should be there.
tashasdaddy
Re: Evinrude 70 hp
welch plug is a silver disc about the size of a Quarter, on top of the engine. it has the numbers.
lloydy
Re: Evinrude 70 hp
There is nothing wrong with it but was told it was a 96 mod and a boat macanic told me it was earlyer than that so I want to find out so I can get a Manual. Thanks you all for your help.<br /><br />Lloydy
ob
Re: Evinrude 70 hp
A 1996 model will have an "ED" near the end of the model number.Try to make out the entire model number if possible and repost.Someone can steer you toward the exact year model.
lloydy
Re: Evinrude 70 hp
I have found out it is a 92 mod but now have another problem. I was cruising along close to full throttle and the engine just died and can only get it started again with the chock lever up<br />but as soon as I put it down to go it dies again.<br />Has any one have any ideia what could be causing this to happen.<br /><br />Thanks Lloydy
tashasdaddy
Re: Evinrude 70 hp
make sure your gas line was connected in the right direction, arrow on bulb points toward engine. check you spark, compression, are plugs wet or dry. and post back.
Ranger01
Re: Evinrude 70 hp
Wet plugs often mean there isnt any spark. Have you done a spark test?
tashasdaddy
Re: Evinrude 70 hp
lloydy, is this motor new to you, when was the last time it was run prior to your problem. check for spark, if you can check compression, look at the coils, are they cracked, leaking discolored? was the gas fresh or did you use what was just in the tank? when was the last time the carbs were cleaned/rebuilt? let's start to narrow thing down. by the way welcome to boating University, i boats.
lloydy
Re: Evinrude 70 hp
The boat is new to me but have taken it out 3 times prior to the break down. It sat around for about 4-5 years before I got it. The motor still runs with the chock leaver still up but sounds sick as soon as I put down the leaver it stops. I think you might be right about the carbs I going to put the boat in for a service and get them done. Thanks you all for your help. Great site and very helpfull.
