Evinrude 150 HP HELP HELP
ceo
My 1995 evinrude has new VRO pump, POWERPACK, Reg/Rect, vacum switch , fuel filter,, key switch and a black switch with two wires black/yellow(located in the RH lower)<br /><br />The motor start for only 5 to 30 secs and dies.<br /><br />There is no difference between the old and new parts. also changed the fuel and oil.<br /><br />The spark plugs NGK for 2 cycle motors, it can be the problem? has the power pack a circuit checking the spark plugs resistance?<br /><br />Gracias, Sud America CHILE
Dhadley
Re: Evinrude 150 HP HELP HELP
Welcome!!<br /><br />For starters (no pun intended) lets check compression and then if thats OK lets get the right plugs in there. Use the Champion QL78YC or the QL77JC4's. <br /><br />You said you changed a lot of ignition parts but never mentioned if you have a good strong spark or not. Since it does start & run for a short time we assume it does.<br /><br />Almost sounds like the carbs are dirty. Have they been cleaned (soaked) and had new kits installed?
Dhadley
And just to avoid confusion down the road -- that motor didnt come with a VRO (Variable Ratio Oiling) pump, it's an OMS pump (pumps a relatively steady 50:1 all the time - will vary slightly). Just make sure someone didnt put a VRO pump on it. It'll still run but it may cause confusion later.
Melvin Hatcher
Originally posted by CIEO CHILE:<br /> My 1995 evinrude has new VRO pump, POWERPACK, Reg/Rect, vacum switch , fuel filter,, key switch and a black switch with two wires black/yellow(located in the RH lower)<br /><br />The motor start for only 5 to 30 secs and dies.<br /><br />There is no difference between the old and new parts. also changed the fuel and oil.<br /><br />The spark plugs NGK for 2 cycle motors, it can be the problem? has the power pack a circuit checking the spark plugs resistance?<br /><br />Gracias, Sud America CHILE
Are you priming it enough and when it start, do you try the primer again just before it die again?
andy6374
Listen to Dhadley and just make sure the tank vent is open.
ceo
Originally posted by Dhadley:<br /> And just to avoid confusion down the road -- that motor didnt come with a VRO (Variable Ratio Oiling) pump, it's an OMS pump (pumps a relatively steady 50:1 all the time - will vary slightly). Just make sure someone didnt put a VRO pump on it. It'll still run but it may cause confusion later.
ceo
Thank you... in my evinrude service manual the pump N°435555 is called "VRO" pump(new and old pump) , by the way i´m waiting for the Champion QL77JC4 spark plugs to do the test.
ceo
Originally posted by Dhadley:<br /> Welcome!!<br /><br />For starters (no pun intended) lets check compression and then if thats OK lets get the right plugs in there. Use the Champion QL78YC or the QL77JC4's. <br /><br />You said you changed a lot of ignition parts but never mentioned if you have a good strong spark or not. Since it does start & run for a short time we assume it does.<br /><br />Almost sounds like the carbs are dirty. Have they been cleaned (soaked) and had new kits installed?
JC1933
Cieo,<br /><br /> If you check again in your manual I think you will finde it is called a (VRO2).That is what my manual calls it. Have a great evening... ;)
ceo
When i started with the engine the first problem was "no spark on any cilynder" for that reason, (reading the service manual), i change the Power Pack, the last reason was change the sparks, localy i found a standard NGK 2 cycle spark with the mentioned results. <br />I have to do the compression test but i think the engine was good because the last year used was 1999 with any problem on it. I will try to clean the carbs to after the Champion spark test.<br />Question? in the service manual they advise problems ussing non-suppression spark plugs, is the power pack detecting the wrong NGK´s and it´s die?<br />Espero respuestas en español tambien!!!
ceo
Originally posted by jc1933:<br /> Cieo,<br /><br /> If you check again in your manual I think you will finde it is called a (VRO2).That is what my manual calls it. Have a great evening... ;)
ceo
ceo
The engine is running ok.<br /><br />All the ploblem was the spark plugs, it was changed for the champion QL16V. The QL77JC4 was not available in stock.<br /><br />Thank you<br /><br />Christtian, CHILE
