failing power packs
bansheetaz
Re: failing power packs
on mine i disconnected that wire at the key switch and at the main harness plug at the engine and with the key off there is nothing but with the key on i have 50 mv which trickles down to about5 mv. i ohm checked that wire with the rest of them in the main cable and its not shorted to any other wire. i was wondering if its just voltage being induced by the other wires in the loom being so close. any thoughts?<br /><br />troy
tonysaoutboard115
i,have replaced all 4 ignition coils,and a new engine wire harness,removed black/yellow wire checked for voltage,with key on/off ok drove boat today ran fine came in and dock for 2minutes tried too re start no spark at all in not in 1,2,3,4 coils i do not have any idea why this is still occuring ? remember this is my 4th or 5th pack that i have replaced
Joe Reeves
Did you check that black/yellow wire for voltage as I mentioned above in my previous reply?
Vigilante
For what ever it's worth.. It took me 2 PPk's to want to replace the entire ingition system to a GM automotive one. Parts are cheap and available everwhere. No proven prototype yet however I'm working on it. I'm not big on spending big $$$'s on parts that continually fail. Disclaimer: I may be insain so don't sell the farm yet.
Joe Reeves
It would be nice to obtain an answer once in awhile. I think I'll abandon this thread. Sometimes I wonder why I bother.
Xcusme
Originally posted by Joe Reeves:<br /> It would be nice to obtain an answer once in awhile. I think I'll abandon this thread. Sometimes I wonder why I bother.
After 3 months, who could blame you. :confused:
tonysaoutboard115
want too apologize,for not responding i though i ansered that question in my last statement, i wantted to get the new engine harness on and then retest everything,but i did remove the black/yellow wire,and check the voltage,it had no voltage too it with te key on/off i wll recheck one more time,the boat rusn fine when it starts, no problem at all when running only when i cut it of and trie to restart no spark, if i have offende anyone i want to apologize,you guys have been very helpful too me do not want too loose your experience and knowledge on boats
