Fishing line behind prop
Bushleaguer
When putting 115 spl, 1997, away for winter, found a ball of fishing line behind prop. Unwond it and removed, had some peel out from behind the seal around the prop shaft. Seal around shaft is not torn up and looks ok. Do I need to take apart and reseal? Lower end oil looked OK when I drained.
R.Johnson
Re: Fishing line behind prop
If it does'nt leak, it could be OK, but the prop shaft seal's are very easy to change.
