tach setting
driver27
I have a 1996 115 spl evinrude crossflow. Could someone tell me what my tach setting should be? <br /><br />Thanks
MCM
Re: tach setting
Van, most OMC motors use setting 6 for 6 pulses, but I think in your case you have a 5 amp stator and as I understand it that would indicate that it puts out 5 pulses in which case you would want it set on setting 5. Note that I'm not 100% certain on this theory though. Maybe someone else might be.
MCM
Re: tach setting
I might add that from experience if you set it on the wrong setting your readings will be off by about 20%, meaning if you set it on 5 and it should be on 6 your tach will read aproximately 1200 rpm's higher than its actually running and visa versa.
R.Johnson
Re: tach setting
It's a 12 pole, 6 pulse, alternator, The setting is 6. Amp's has nothing to do with it.
Dhadley
Re: tach setting
Position 6 is correct for the V4's. Looper and crossflow.
MCM
Re: tach setting
I think I'll go find a foot puller :D
driver27
Re: tach setting
Thanks to everyone for the info. I believe it is set on 5 and does seem to read high. I will make sure its on 6 now. <br /><br />Van
rodbolt
Re: tach setting
a quick note is to count the wires on the rectifier, to my knowledge all the V4 and up set at 6 pulse but the 4 wire rectifiers on the 3 cyl and 2 cyl motors set at 5 pulse.<br /> makes a bit of a difference in the tach reading.
