voltmeter readings
Alejo
Hi! I run a Johnson 150HP Fast Strike 1995 outboard equipped with Faria voltmeter. At idle or 1000rpm voltmeter reads 12V, at higher rpms (2500 to 3500 or more) reading is 14.5 V.<br />Is this normal? Should I check voltage regulator or alternator?? Tks in advance for your comments
Laddies
Banned
Re: voltmeter readings
Thats about normal the alternator don't do much at idle
Alejo
You mean that alternator/volt regulator supply a variable output voltage depending on rpms?
DHPMARINE
Alejo,<br /><br />That is exactly how they work.<br /><br />DHP
Silvertip
A regulator regulates the high end voltage to prevent over charging. It does not have any affect on the low end.
Alejo
Tks for the input gents. Have a nice week-end, greetings from Buenos Aires, where spring is welcoming boaters!
Scaaty
Originally posted by Alejo:<br /> greetings from Buenos Aires, where spring is welcoming boaters!
That does it...I'm moving! :D
