Running motor with earmuffs on
11craigt
Just put new power packs, plugs and wires on my 115 Evinrude (1983). Running it in gear with some throttle (upto 4000 rpm)for s short time to make sure everything is working the motor makes a kind of garbling exhaust noise...not a precision "prrr". Is that just the way it is being a 2-stroke with no exhaust restriction? Any reply appreciated. Have a great weekend! :confused:
walleyehed
Re: Running motor with earmuffs on
Never run over 2000RPM on the muffs. You can have a run-away, put a rod through the side or maybe even a hole in a piston.<br />There really is nothing you can adjust on the muffs, so there is no reason to run any RPM other than Idle or slightly above.
11craigt
Thanks for the input. Won't be doing that again. What about the roar of the exhaust though? It somewhat is a little rat-tat-tat like? Not smoothe and seamless?
walleyehed
Completely normal with no back-pressure...<br />It smooths out in the water where it has the designed back pressure to scavenge properly.
R.Johnson
If you want to hear noise! A V-6 Merc running on a dyno is hard to beat.
11craigt
Hey cool. Thanks guys, much appreciated. Kinda thought so....but I am still an expert novice. Have great weekend.
