socalxr650
Thread starter- Joined
- Sep 7, 2005
- 5
I recently bought a boat with a 1986 model Johnson 175 outboard.<br /><br />After buying the boat, I took it to a shop and had the entire motor rebuilt from top to bottom. It was hogged out to .45 over, and the mechanic assured me that the motor will now run like a raped ape.<br /><br />I took it to the lake a week ago today, and put it in the water, after allowing it to warm for approximately 5-10 minutes, got under way. <br /><br />Once out of the no wake zone, I eased into the throttle. The response was slow! It took more than half throttle to get to 3,000 RPM. Once I got it to 3,000 RPM and tried to cruise, the motor would surge and then bog. The REVS kept fluctuating between 3000 and 2000. After some trouble shooting I noticed the primer bulb was getting sucked shut when we were at 3000 RPM. Once I pumped the bulb, the motor came up to speed. If I continued to pump the bulb it would run well. Logic tells me it is a fuel starvation problem. I should tell you it has a new fuel filter, and that is not the problem.<br /><br />The boat went back to the mechanic for fixing. I recived the call today that it was ready. The mechanic told me that he took it to the lake and it ran perfect. He adjusted the carbs and "a few other adjustments." The mechanic stated that he was able to run at 5000 with no fluctuation. He statd that the motor held well at all RPMS tested. <br /><br />I took it to the lake after work an could not get the motor above 1500.<br /><br />Sorry for the LONG drown out first post, but I need help! Any advice you guys can give would be great!<br /><br />Thanks in advance.<br /><br />Paul
