trim motor
cryoman
Hey guys i need help, I have a 115 johnson motor 77 model , I think i have a short , I can here the relays clicking where can i find the relays on this clicking when i try to trim up no sound when i try to trim down :confused:
OBJ
Re: trim motor
Welcome cryoman!<br /><br />Only one relay....for up. The relay and associated wiring is usually in a "black box" somewhere in the transom area to keep it outta the weather. Just follow the lead from the motor back and you should find it.<br /><br />You have a problem with either up or down?
cryoman
Re: trim motor
OBJ thanks for the post I will follow up later on progress probably tomorow .Up or down does not work
aanda6
Re: trim motor
Hi Cryoman,<br />any update. I was following your post as I have simmilar issue and was wondering what the outcome was.
