1989 Johnson 15 longshaft(20") J15RLCEC Bent Shift Rod ?
Lowranger
I had to pry to seperate the lower unit(with 5" extension)from upper assembly to get my 3/8" socket onto the upper hex-head bolt to release the shift-rod. Upon examination, it appeared that the shift-rod was bent rearward 15 degrees. http://www.c-brats.com/albums/Adeline/Bent_Shift_Shaft.sized.jpg and I became concerned that I had bent it with my prying. I went on to examine the shift -rod in the gearcase and found that it was also bent in a way that matches the upper shift-rod(i.e. 15 degrees forward) web page C-Brats and now I wonder if there was always a "dogleg" in the shift-shaft. Since this is my first dis-assembly I simply don't know. Can an experienced wrench show me the light? Is this bend normal?
diggerdan17
Re: 1989 Johnson 15 longshaft(20") J15RLCEC Bent Shift Rod ?
i also had to pry like abugger to get my lower unit off of my 15 horse evinrude 2 nights ago and saw that my linkage was kinked a bit ....needless to say i think thats the way they are made because i,ve reassembled mine and rebuilt the carb and its running better now than it ever did.good luck with that.
Lowranger
I too think that the " Dog-Leg" is normal. I checked a parts diagram at "ISHOP MARINE" and it was there. Thanks for your kind reply. Happy Landings, Pete
