whitejamie99
Thread starter- Joined
- May 12, 2005
- 105
Just got the boat back from the shop after an extensive period of repairs - impeller, head gaskets, replaced carbs. I couldn't get the link and sync right so I took it to a local mechanic who fixed a couple of my linkage mistakes and got the boat running correctly. He did not do a WOT timing check though. He also told me that the float was too high on the top carb and that was causing it to "load up" at idle. The symptoms now are rough idle and wont run smooth at low RPMs in gear and when taking off it bogs down and dies. After several tries and playing with the throttle, it will plan and run very well. What do I check now?<br /><br />Jamie White
