Re: help!!!! 78' johnson 70hp
Remove the carburetor face plate. Observe the carburetor throats while pumping the fuel primer bulb..... If fuel escapes, the carburetors need cleaning and rebuilding.<br /><br />NOTE.... When a engine has more than one carburetor, and one unplugs the fuel line to let the engine run out of fuel, the top carburetor runs dry of fuel (and OIL), leaving the engine to continue to run on the remaining carburetors.<br /><br />This results in having at least one aluminum piston run up and down the steel cylinder wall with improper or no lubrication. Not a good idea!
