rolmops
- Feb 24, 2002
- 5,709
I completely rebuilt a 1986 50 horse evinrude.I replaced the pistons had the cylinders done 20 oversize,replaced the seals and so on.So it is completely rebuild now.Also the VRO was replaced with a regular fuel pump.It still sneezes a bit while running on the muffs and I suspect the fuel supply manifold hoses to be too small.<br />When I tried to determine what cylinder was running lean and sneezing I put my hand over the carburetor mouths and found out that while trying the upper carburetor it hardly lowered the rpm but gave a lot of fuel in the barrel,while when covering the lower carburetor it would shut the engine down.Same thing with pulling the plug wires.When pulling the top wire off the plug It would make a little difference but not much.When pulling the wire of the lower plug it would shut the engine off.Am I looking at a reed job or is this possibly something electronic?<br />As always your help,advice and opinions are highly appreciated.<br />Rolmops.
