Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
I was greasing the two fitting on the "turning" pivot (don't know what its called, not the one for the steering cable) and the grease that came out looked to be wheel bearing grease. Manual says to use Triple Guard. Should I just start using the T/G grease or try to flush out all the old grease with fresh T/G by pumping it in from grease gun? <br /><br />I don't want to waste grease, so if the two are compatable for those bearings, I will just start using the T/G and not worry about what is in there now.<br /><br />Sound OK?
