Hi, I have a 2004 40hp Johnson which won't start b/c the carbs are flooding big time. I have tried adjusting the float / needle with no luck. The motor has been used less than 10hrs, do you think I should install new carb kits on this new of motor? Could it be something else that may be causing the carbs to flood. They gush fuel when starting the engine and/or priming it - not just a little, but a lot. Thanks.
