Not reaching max RPM!!!
ddbyrd3
Re: Not reaching max RPM!!!
[/URL][/IMG] <br /><br />This is the block.... #1 cylinder is on the left side of the picture..
ddbyrd3
[/URL][/IMG] <br /><br />Here is the head.. #1 is on the left side of picture..
Basscat 1
If you were getting water in cylinder #1, the spark plug would look clean. Its hard to tell from the picture, but the plugs look the same.<br />The piston does look like its running leaner.
ddbyrd3
The plugs and combustion chambers (the heads) are identical looking.....<br /><br />#1 cylinder is the only "dry" looking piston..
ddbyrd3
[/URL][/IMG] <br /><br />This is a pic of #3 piston, 2 and 4 look more like this one....
Basscat 1
Check your top carb and make sure its not running lean. I would pull it off and tear it down and inspect the jets and fuel circuits.<br />Clean it with compressed air.
ddbyrd3
Did that a couple weeks ago... I let them soak over night in carb cleaner, and blew 140PSI compressed air thru those bad boys... rebuilt them with OEM kits...I feel confident they are good to go.....<br /><br />Now, reeds are a different story....
ddbyrd3
A hole in it, you mean like the #3 piston.<br /><br />Piston 1, 2, & 4 are standard bore, #3 is .020 over..... and the only one with a hole in it..
Blueclaw
run the boat on the water and check the full advance timing
ddbyrd3
Thats pretty daring, 5000RPM across the water with the engine cover off , yee haw!!!!!! unfortunitly I believe I may have to do that in order to elimanate any possibility of timing being an issue....<br /><br />Wish me luck..... This weekend I will have to try it...
Basscat 1
Yea, send us a picture of that. :D <br />The Army may have a job for you; In Flight Missle Mechanic.
ddbyrd3
Yea, "um excuse me sir, are those your intestines hanging out of your stomach???????"<br /><br />after the flywheel eats me up like a meat grinder.
Basscat 1
Around here, we call that bait. :D <br /><br />Just kidding. Be careful doing it that way. <br /><br />Be sure and check your cylinder heads with a flat piece of glass and a feeler gage while you have them off. ;)
ddbyrd3
I reinstalled the heads yesterday... all checked out and looked good, so I will test the boat and my balancing ability soon.......
ddbyrd3
Basscat, I have been following all of the post on the OMC Guru's thread, it appears this 5000 MAX RPM issue crosses over all size motors...<br /><br />Its pretty interesting, I cant wait for someone to figure it out.... They should recieve a prize.....<br /><br />Tomorrow I plan on running with engine cover off and verifying timing.....<br /><br />Checking the flywheel key, what should I look for, I have intentions of checking mine just because......
Basscat 1
I was only reaching 5300 rpms max on my boat at wot, but I think I found out why by accident. My tach wasnt working so I bought a new OMC tach. It seems somebody told me that my tach should be set on 6P, but by accident I found out this was wrong. Mine should have been set on 4P which turns out the rpms will rise. A silly mistake I should have caught sooner.<br />I havent taken the boat out on the water, but I feel real confident that I will reach my 5800 goal, or at least come close. <br />Here check this out. web page<br /><br />When checking the flywheel key, make sure it fits snug and tight in both the crankshaft and flywheel. Make sure its not worn.
ddbyrd3
Interesting..... When I pull my flywheel I will count the number of poles.... It may very well be the same thing... <br /><br />I had an OMC tach last time and now I have a Teleflex gauge set....<br /><br />Maybe I have been chasing my tale this whole time... wouldnt that stink.....<br /><br />The question I have though is the top end speed difference... although I have a different speedo as well...<br /><br />Now you really got me thinking!!!!! and that alone is a scary thought....kinda like the intestine thing.....
Basscat 1
OMC tachs are the most accurate. All factory speedometers are not to accurate. When judging the speed, gps is the only accurate way.
ddbyrd3
I hear ya... I will start with counting the number of poles on my stator, get the tach reading right and let the speed fall where it may..
