xyourobob175
- Jun 26, 2005
- 23
This is deep so hang in there. I have had the engine since last year. It has had the FFI Enhancement update kit.<br />The engine overheats consistantly. I changed the water pump twice (both times with ugraded water pump & two different mechanics). I changed the gauge & engine sensor. I changed the thermostats and thermostat springs. I removed all gear from transom and tested boat. Same problem!<br /><br />The boat runs like a champ without the thermostats in. High rpms the engine temp stays between 160-170 degrees. I would prefer to run the engine with the thermostats in place and I believe it's healthier for the engine.<br /><br />Whats my next step other than ditching the engine? Any experts out there?<br /><br />Model #J175FSXECS<br />Serial#04500671<br />xyourobob@comcast.net
